In total there is 1 user online :: 0 Registered, 0 Hidden and 1 Guest :: 1 BotNone
WTS SPark Car care servicing Package X 02
Dear All,
i am selling my Spark Car Care Servicing Package from ComfortDelGro.
Pls call or sms for more details at 91462635
They have 7 branches which you can use the package at.
Detail and location of the branches at www.sparkcarcare.com
i have 2 packages selling for
1) Essential Service $98 - Selling for $68,detail below
2) Premium Service ($258) - Selling for $228, detail below
1) Essential Service Package
Change - Engine oil (up to 4ℓ) SPARK PowerSyn™ Fully Synthetic Oil (SAE 5W-40), Oil filter (original or equivalent) , Drain plug washer
Clean - Air filter
Check - Drive Belts & Cooling System. Drive belts , Cooling hoses & connections ,Electrical ,Light / indicators ,Battery condition ,Wipers ,Steering & Chassis ,Shock absorbers ,Tyres,Brake Parking brake
Top-Up - Power steering fluid , Battery water , Brake / clutch fluid , Radiator coolant , Windscreen washer water
FREE Car wash , Interior vacuum
2)Premium Service Package
Special Treatment - Engine flush & Anti-bacteria clean-air treatment
Change - Engine oil (up to 4ℓ) SPARK PowerSyn™ Fully Synthetic Oil (SAE 5W-40), Oil filter (original or equivalent) , Spark plugs (4 pcs – standard) , Drain plug washer
Clean - Air filter
Check -Engine, Drive Belts & Power Train , Drive belts & V-belts , Fan belt / air-con belt , Engine mountings , Transmission / axle oil level , Cooling System , Cooling hoses & connections , Radiator fan , Radiator cap , Electrical , Light / indicators ,Battery condition , Wipers & horn , Air-Conditioning , Cabin filter ,Steering & Chassis , Shock absorbers , Tyres , Side-slip , Ball joints , Brake & Clutch , Parking brake , Brake discs / drum ,Brake line pipe & hoses ,Emission ,Exhaust muffler & pipe connections
Check & Perform-Rotate tyres , Balance all wheels ,Lubricate lock hinges & hood latch
Top-Up- Power steering fluid ,Battery water ,Brake / clutch fluid ,Radiator coolant ,Windscreen washer water
FREE-Car wash , Interoor vacuum and Nitrogen gas for tyres
Clean - Air filter
Clean - Air filter
Goodspeed- Learner
