In total there are 4 users online :: 0 Registered, 0 Hidden and 4 Guests :: 1 Bot
Fidanza Flywheel
Fidanza Flywheel
Post  wishxsr on Sat Jan 05, 2013 3:49 pm
Selling 1 pc of Fidanza Flywheel for Elantra 2011 (Brand New in Box) due to last minute cancel from my friend as he is changing his ride soon.
Price @ S$450 ( Bought it at USD 373.90 from HPF),Can be install in a workshop in Tagore @ $170.
Fidanza aluminum flywheels are made from the highest quality 6061 T6 aluminum. The material is fantastic for strength, heat dissipation and of course reduction in weight. The friction surface used is an incredibly strong 1050 steel. The plates are milled to meet Fidanza'a high specifications. A Fidanza flywheel can mate with any type of clutch material, including organic, kevlar, ceramic, metallic and sintered iron. Fidanza attaches the friction surface with military grade aerospace fasteners. The ring gears used are also made from 1050 steel and are heat treated for durability. The gears are heated then pressed on and secured with grade 8 button screws. Fidanza was the first to utilize a stepped dowel system in most of their flywheel applications. This doweling method ensures that once the pressure plate is installed the dowels cannot be removed because they become locked into place. Fidanza designs and builds flywheels with extreme precision, giving tuners, racers and builders the high performance and unmatched power they're seeking.
Fidanza Flywheels help:
Any street or race engine produce more usable horsepower!
Any street or race engine lasts longer due to less stress on the crankshaft and bearings
My ride is currently on this flywheel for 6 months and its freaking good stuff.
Do PM me if interested
Thanks and Happy New Year to all bro here.
wishxsr
wishxsr
Re: Fidanza Flywheel
Post  Terry_gerrard on Sun Jan 06, 2013 5:30 am
What is the weight of the flywheel?
Post  wishxsr on Sun Jan 06, 2013 6:28 am
Terry_gerrard wrote:What is the weight of the flywheel?
The size is (96-7/99) 41mm Crank and weight of 14lb (average 60% lighter than Oem).
wishxsr
wishxsr
Post  wishxsr on Mon Jan 07, 2013 6:54 am
THANKs . SOLD.
wishxsr
wishxsr
