In total there are 4 users online :: 0 Registered, 0 Hidden and 4 Guests None
AIRCRAFT GRADE Permanon now available! Mobile Grooming/DIY!
+10
p226
spidercool
Petrelli_83
watme
Elan Suarez
Spookz
beacon enterprise
14 posters
Page 1 of 12
Page 1 of 12 • 1, 2, 3 ... 10, 11, 12
Imported from Germany and endorsed by premium car brands like Lamborghini (Sydney), Permanon Platinum is a high quality surface protection engineered to the nano level for ultimate shine and protection. Not only will the high gloss shine impress you, but the nano-coating provides protection against the harsh elements superior to what expensive clay and wax solutions can offer. Cleaning is also made easier for Permanon coated cars by up to 80%.
Look good and feel good not enough for you? The water repellent nature of the nano-coat is an additional safety feature as water glides off your all your mirrors upon application (applicable on all mirrors and glass surfaces!), giving you clearer vision on those rainy days.
Just dilute and spray on your designated areas, that's all you need. The electrostatic bonding nature means 1 spray on application lasts 6 months while the applicability of the product on both internal and exterior surfaces translates into massive cost savings for you (egs, Spray on your tyre rims to maintain shine while preventing accumulation of brake dust).
Seeing is Believing - Watch the videos now!
Click the following links to download our brochures
(1) Permanon Platinum
Make your purchase now @ http://www.beacon-enterprise.com
For enquiries,
(1) You can call us @ 93472184 (Jonathan),97661548 (Jerry)
(2) Email us at enquiry@beacon-enterprise.com
For enquiries,
Last edited by beacon enterprise on Wed Sep 26, 2012 7:44 am; edited 3 times in total
beacon enterprise- Driver
Re: AIRCRAFT GRADE Permanon now available! Mobile Grooming/DIY!
How does Permanon work? Why does it last so long? All your questions answered in this in-depth review of Permanon technology!
http://www.metalfinishing.com/view/15600/p...ting-technology[/size]
Permanon is a brilliant 21st century surface protection that eliminates the need for buffing or polishing and is conveniently sold as a concentrate so that you buy less water and more protection. Permanon utilizes waterborne nano-engineered particles of Silicium (14Si) that electrostatically bond to the surface being protected. There is no chemical or mechanical action to damage, or alter, the surface you are protecting. Permanon is designed to protect polyurethane topcoats and other solid surfaces such as glass, FRP, stainless steel, chrome, rubber, finished leather, granite, varnish, enamel, and solid surface products. Permanon protection will outlast any wax or oil based renewable surface protection and comes specially formulated for Aircraft, Yachts, Boats, Cars, Trucks, Interiors, Pool & Spas, and Glass
Permanon features the following capabilities:
Dirt cannot bond to treated surfaces
Surfaces are protected against industrial and environmental Pollution
Repels airborne dust
Eliminates the need for harsh and potentially dangerous chemical cleaners
Reduces cleaning costs by 50% or more
Improves clarity of transparent materials and reduces light scattering
Resistant to temperature extremes from 40°C to 300°C
Resistant to ultra violet (UV) exposure, undiluted provides 100% UV protection Anti-fouling properties
Significantly improves the “maintainability” of man-made surfaces
HOW IT WORKS
All materials are porous and contain microscopic peaks and valleys, much like the profile of a mountain range. These irregularities are known as capillary structures. On manufactured surfaces (including paints and coatings) there may be millions of these defects per square inch. Contaminants such as fine dirt, minerals, and pollutants are drawn into the voids where they are extremely hard to remove. Capillary structures also provide microbes and bacteria with an excellent place to grow and multiply.
The silicium particles of Permanon are laminar shaped, which means they overlap each other like the scales of a fish. These platelets are deposited on the capillary wall and closely follow the contour of its surface. These platelets will fill up to 90 percent of the capillary void, resulting in a surface that is smoother and more resistant to soiling. The overlapping of the platelets also reduces the permeability of the treated surface, making it virtually impossible for moisture and other reactive agents to migrate through the protected coating to the metal surface.
I’ve been testing this for about 8 months; when you apply it to a clean surface, that surface virtually takes on properties of hardened glass. It’s easy to clean, protects against UV light. What I like most about it is permeability control. When you spray it on a hard surface, it achieves a contact surface of 160 degrees and it virtually eliminates the transfer of moisture or other chemical compounds through the existing coating to the substrate.
Super water repellant. The filling of the capillary structures with silicium nanoparticles produces a hydrophobic surface. (A hydrophobic surface is one that repels moisture.) In contrast, a hydrophilic surface is one that absorbs moisture. The potential of a surface to absorb or repel moisture is based on many factors, including: temperature, relative humidity, material homogeneity, and static electricity. Surface roughness is also a major factor; the rougher the surface, the higher the spreading rate or attraction for water. The smoother the surface, the more repellant it is to moisture.
Close up photos of water Beading on Permanon-ed Car after heavy rain
HOW IT WORKS
Photos and review contribution from our valued customer, Andy Chan
I used to get professional car polishing gurus to do up my ride. This was until I bought a bottle of permanon from Jerry after hearing about it from some of my friends. I must say I hestitated for 2 weeks before deciding to call upon Jerry because I am extremely skeptical of car grooming product.
I recalled that evening I went to pick up the permanon from Jerry, he took the pain to explain the instructions to me. I would like to thank Jerry for his effort. After about 10 minutes of instruction, I bidded farewell and promised to call him if I do not know how to do it properly. I zoomed back home and started on the permanon immediately. Application was very easy and took me half hour to go through the entire car. The results are astonishing! Water marks are gone and water droplets no longer stick onto the surface of the glass and car. In the past, I only get this kind of result after detailing with thick car wax and only for shortwhile. With permanon, its seems to be permanent even after weeks without washing or re-applying the permanon.
When I wash the car now, it can be done with water and no shampoo. I am also very impressed by how easily bird droppings and dirt got washed off as if permanon has some kind of anti static capability. This is my third dose of permanon and I maybe overdoing it in such a short interval. But one thing for sure, car washing has never been so easy for me! I am not a very charitable person when it comes to singing praises. But, after using permanon, I tell myself that I must write this letter to you give credit where it is due and thank Beacon Enterprise for this remarkable car detailing product.
Why didn't those car polishing gurus thought of permanon before?
Regards
Andy Chan
Visit our facebook to view more reviews!
Regards
Andy Chan
Photos and review contribution from our valued customer, Andrew, VAGS
Last sat i tried the Brilliant shine n permanon,the effect was so gd that after i wash wif brilliant shine n dried the ride,the ride was so shining that make mi wanna skip applying permanon process :p but still i go ahead wif permanon,the water beading was really great and its a gd products tat save mi alot of time although i still took abt 1 hr to complete the washing as i use the products for the engine bay too...
Visit our facebook to view more photos!
Photos and Review Contribution from Our Valued Customer, Edwin
Having used Zaino's Z8 and CS, I had a rather high benchmark for permanon. Needless to say, I was not disappointed with the shine after 15 mins of application. However I was only truly impressed on a rainy day. Normally there would be water marks after the rain evaporates and I will be extremely anal in cleaning the car to prevent the marks from being etched in. I was surprised to find little to NO water marks ! Furthermore they provide really good service and answered all my questions numerous times on their live chat. Thumbs up for permanon !
Edwin
To receive the latest updates,reviews and promotions, click to join Beacon Enterprise Facebook page. =)
Edwin
Nissan GTR
No equipment, no machinery required
Spray on and wipe off. That's all you need for Permanon Surface Protection
Just wipe off with Microfibre cloth
Water beading immediately after application. No baking or curing required
Permanon surface protection is extremely hydrophobic (water repellant)
Visit our facebook to view more GTR photos and reviews!
Photos and Review Contribution from Our Valued Customer, Wilson Tan from VAGS
Bought the Supershine couple of weeks back but finally managed to do it last night. The toughest work was lugging a pail of water from house to car park...
Couldn't really see the result last night. This morning the sight made all the hard work well worth it.
The BrilliantShine and Permanon is a great combo.
Thanks!
Regards,
Wilson Tan
Thanks!
Regards,
Wilson Tan
Photos and review contribution from our valued customer, Andrew, Kia
Hi Everyone,
Would like to share my experience from using brilliantshine and permanon for the past 3 months. Seriously speaking washing my car has been a breeze after being recommended to use these 2 fabulous products.
Firstly, when using brilliantshine for washing my car, the paint coating will have a shiny mirror like look and touching it up with permanon protects my car paint from the sun. As i park in the open air, this is something i am rather particular with.
Secondly, My sports rim are always shiny and oil free when using the both products. Also my fear of parking outdoors is bird s--t stains which is an irritant to car users like us. After using brilliantshine, the stain comes off easily especially when the stain has been there for along time.
Thirdly, Juddering sound effects no longer bothers me after using them.
That is why i would like to express my thanks to beacon enterprise for providing me with a cost saving car wash and protective solution for my car.
Keep up the good work and hope to hear my promotions from you guys.
Cheers.
Best Regards
Andrew
Hi Everyone,
Cheers.
Best Regards
Andrew
Photos and review contribution from our valued customer, Lawson,Subaru
A picture speak a thousand words.
My car is already 3 and half yrs,and the product makes my car shine like new!
I am very satisfied with the shine on my car.
Best regards,
Lawson
Chan Chee Hao
Best regards,
Lawson
Chan Chee Hao
Photos and review contribution from our valued customer, David
Hi there,
I must congratulate you for this good product that I have waited for a long time.
It was really an easy and effortless chore for me to do up 2 cars in 1 hour. My wife was surprised when she saw the 'bling bling' on her 6+ years old car. Attached are the pictures of my drive, her car is besides mine.
Keep up the good works
Hi there,
Imported from Germany and endorsed by premium car brands like Lamborghini (Sydney), Permanon Car Supershine is a high quality surface protection engineered to the nano level for ultimate shine and protection. Not only will the high gloss shine impress you, but the nano-coating provides protection against the harsh elements superior to what expensive clay and wax solutions can offer. Cleaning is also made easier for Permanon coated cars by up to 80%.
Permanon products have been specially designed and engineered so that no special procedure or extra sanding will ever be required to remove Permanon products for repainting! The normal, standard surface preparation procedure that must be carried out to re-paint a yacht properly is more than enough to completely remove all Permanon coating elements! This is another very important unique benefit of Permanon products!
Permanon products are mono-molecular and not tri-molecular like other products, Permanon products only seal up to 90%, blocking water and moisture whilst allowing the surface to breathe. This is very important for leather and fresh paint, as ‘out-gassing’ the releasing of solvents from freshly applied paint is not prevented.
Permanon Supershine is very easily applied by simply wiping or spraying Supershine on any pre-cleaned non-porous surface, then hand dry or rinse. Since Supershine connects to surfaces statically no waxing, compounding or buffing is needed, just hand drying (reachable surfaces) or rinsing (hard to reach surfaces) is required for application.
(1) 3 Reasons for Using Permanon Car Supershine
(2) Permanon is Resilient
(3) Permanon Car Supershine
Just $30 for 1 year's worth of shine, protection and safety .
(1) Permanon Car Supershine
Lazy to diy? Want a professional groomer to prep your surface and apply permanon for you while cleaning interior as well? We provide Permanon application services too!
Review on Permanon
How does it work?
To me, this is the most fascinating part about it. This technology actually came about as a result of a laboratory mishap which yielded a result that would ultimately become Permanon. Most surfaces in nature have a negative charge to them. These surfaces include the painted surface on your car whether it be metal, plastic, aluminum or carbon fibre. Glass and plastic are also negatively charged. In fact, if you apply a wax, sealant or nano glass coating to the surface such as Opti Coat or CQuartz, the surface retains its negative charge. Permanon contains silicon which has in nature a positive charge. You know what happens if you hold 2 magnets to each other with a negative side on one and a positive side on another: they attach themselves to each other very quickly. This is exactly what happens when you spray Permanon onto the surface of a non porous material. The protection in Permanon attaches itself to the surface. Not only that, but the true chemical beauty of it is that the surface has now changed polarity and has a positive charge. The significance of that is that dust, dirt and water are actually repelled by the surface of the material. Just like trying to bring 2 magnets together of the same polarity....ain't gonna happen!!
What can it be applied to?
As previously mentioned, non porous materials. What it will not work on is a much shorter list than what it will work on. Do not apply to cloth, unsealed leather, and rubber. Metal, plastic and glass are primary examples of what can be treated with Permanon. The metal can even be bare. I treated raw aluminum with Permanon Platinum and it sealed it and protected it against oxidization and finger prints. You can pretty much apply Permanon to the entire outside of your vehicle. Paint, glass and trim. It will not hurt the tires or rubber if it is sprayed onto the surface, it just won't yield any protection for that surface.
How can it be applied?
Permanon, either Auto or Platinum, comes highly concentrated. In fact, you can use either a 5 or max 10% solution of Permanon to 90 to 95% of distilled water. Application can be via a pump sprayer of the garden type variety or even through a pressurized paint gun. You do not need to soak the surface. Just mist it on until you see the water on the surface beading and then you know it has bonded. The surface does not need to be previously wiped down with an alcohol wipe or equivalent. Make sure the surface is clean and dry...that's it!
How do I remove it?
OK, if the technology of this product didn't set it apart already, wait to you hear this: you can actually apply and remove this product without touching your surface! Once the Permanon has been applied, it can be immediately removed as the bonding process is instantaneous. All you are doing at this point is removing the distilled water that was used as a carrier for the Permanon. So, to remove that water without touching your paint, use a leaf blower or auto blower such as the Master Blaster. You don't want to leave the water on the paint, even if it is distilled, since you may get water spotting with it. Voila! You have just protected your surface without actually touching it. That method is my personal suggestion. Permanon suggests drying the surface with a micro fiber drying towel. Fair enough, but we all know that any time you touch the surface, you risk instilling marring of the paint. My method prevents that.
What kind of durability can I expect?
Permanon is not removed by normal cleaning products. You can remove it with an alkaline PH of 12.5 or greater which is extremely high on the scale. Most acids will not remove it although hydrofluoric acid can as well. These 2 examples are not something to which you would ever subject a painted surface! Otherwise, it will stay active for approx 6 months on a daily driver. A "Garage Queen" could theoretically stay protected for years.
What about maintenance?
Permanon will not adhere to itself. (Remember the magnets of the same polarity?) However, if there is an area where the Permanon has started to fade from, simply go over that area with new Permanon and it will bond to the low spots or the spots where it is no longer active. If in doubt, just go around the whole car again.
Permanon's Strengths:
I've already mentioned the repelling of dirt, dust and water. One of the key attributes to Permanon as well is its ability to withstand heat. Where this comes into play specifically with autos is with wheels and the resulting brake dust. When the brake dust settles on the wheels, it is at 265°F. This product can withstand heat up to 572°F!! Therefore, the brake dust cannot burn itself onto the surface of the Permanon-treated wheel like it could with a wax or sealant treated surface. Cleaning of brake dust just got easy.
For enquiries,
(1) You can call us @ 97661548 (Jerry), 93472184 (Jonathan) 96670623 (Martin)
Review on Permanon
How does it work?
How do I remove it?
For enquiries,
Last edited by beacon enterprise on Mon Mar 19, 2012 4:26 pm; edited 1 time in total
Photos and Review Contribution from Our Valued Customer, Andrew
I have been a user of Permanon product for a few months already. I'm very happy with the product. Even washing rim with brake dust is easy but before that must apply with the Permanon and BrilliantShine. Couple of weeks back, I'm too sick to wash myself, so decided to wash at the petrol station. When the car washer spray the "snow" onto the whole car, to my surprise, the "snow" on the wind screen started to flow down. Followed, he started to clean the whole car then rinse with pail of water. Cos the car wash shampoo is different, it maybe a stronger agent, worry it may wash away the Permanon coating but it didn't.
I travel to KL quite frequent, at least once monthly or twice 3 monthly. The last time I went up North was mid of August. When I reached KL, I noticed there is a insect stain on the bumper area near the headlight. It rain everyday at KL. I've parked my ride underneath trees for 2 days. Rain & shine, the dirt & stain is so observe till I can write on it and the insect stain was wash off. Only managed to wash my ride a few days after I returned from KL cos due to work and rain. After washing, the ride is back to it's shine, to make it better, I used spray-on quick wax for even better shine. Remember, do not use Permanon product on top your current wax, the Permanon product will wash off together with the wax. You have to clay off everything then apply the Permanon and BrilliantShine then your current wax product in case you miss out.
As for wind screen, I don't really like to use wiper so I been using Rxxx-X for my previous ride and this current ride until I tried Permanon and BrilliantShine product. Below is my experience on both product I've tried :-
1- Application on both Rxxx-X and Permanon product.
For Rxxx-X, you need to apply a layer onto the glass and let it "cure" for a while then use a moist cloth to wipe off to give you a clear view. For Permanon, all you need is spray a thin layer onto the glass and wipe off with a clean cloth or rinse with clean water as per instruction.
2- Water repellent and juddering effect on both product.
For Rxxx-X, newly applied gave you superb effect on the water repellent (@ about 50 -60km/h) but after few days with or without rain, the effect of the repellent is not as good as newly applied. Need to drive till about 80 - 90km/h then the water started to flow, so when there is rain, you started to turn on the wiper. After a while, the wiper started to juddered. For Permanon, newly applied also gave you superb effect on the water repellent (@ about 40 -50km/h), as usual, the effect will not be as good as newly applied but no juddering on the wiper.
Above is my personal feedback about the product. Just my $0.000002 worth of feedback.
Cheers,
Andrew
Cheers,
Andrew
Photos and Review Contribution from Our Valued Customer, Jeremy
Rushed down Stamford Tyre after reading about this product.
Really like the fast and easy application, and the result is superb.
Only tried one brilliantshine wash then one application of Permanon Car Supershine which I think it is more than enough.
Been a week and driving for 2 days in heavy downpour and the repellant effect of rain is good, let’s see how long it can last. - Jeremy
Photos and review contribution from our valued customer, Mason
Using the Permanon is just a piece of cake! just follow the instructions told by Martin and you will be able to do it all by yourself.
Although Martin's explanations can be lengthy, but it certainly explains the whole idea of how Permanon works. he goes into great details on how you should do your ride and gives you real advices on what to do. He even called me twice after I left to warn me of certain things that I should not do! double thumbs up for the great service!
Look at my pictures, aren't they a solid prove that Permanon works? it's a simple and fuss-free gem that all car users should try! If you really doubt it's usefulness, I'm sure u can opt for the cheapest bottle to put all the testimonials here to test. I'm sure you will walk away from your car smiling after that.
kudos to beacon enterprise. I'm glad I made a right choice!
Photos and review contribution from our valued customer, Keith, VAGS
Hi people at beacon-enterpise, i must say the product is good and wallet friendly. After reading about the product today, i went down to the nearest Stamford Tyres immediately to get one myself. The after wash/polish effect was good as I could see showroom shine coming back. And yes, i am not going back to my PPS workshop for the half yearly maintenance ever again
Cheers
keith
Cheers
keith
Photos and review contribution from Chun Keong, Sg Fiat
Hi Martin,
First of all, I must thank you for your time to give us the product demonstration. Its unbelievable how easy it is to keep the car water free.
After application, I was admiring the shine and appreciation the extra coat of glass that my car is donning. I had only washed the car with brilliant shine and applied a single coat of Permanon (20ml) and there is still left over! I can see the reflection of the ground on my car clearly! I even took pictures of an adjacent car to compare the reflection.
I think I'm one of the few out there who thinks differently - I wanted it to rain to test this water beading capabilities! True enough, just as I was to award myself a fulfilling lunch after applying Permanon, it RAINED! Yes! On my car that I just groomed! The best part was that the rain was not the heavy type - such that water does not reach it optimal mass to slide off. Its the most perfect way to test Permanon.
I was impressed with how water beads were formed. As a former user of similar products for windscreen, most droplets will not streak away unless they are big and heavy enough. For Permanon, even small droplets are streaking off by themselves even when the car is stationary.
Car lovers know how painful it it to prevent water stains in Singapore but after applying Permanon, I believed it has solved my problem. With the ease of application and yet displaying such wonderful capabilities, I will strongly recommend Permanon to fellow car enthusiast who love keeping their car shiny and water stain free.
- Chun Keong from SgFiat
Hi Martin,
Photos and review contribution from Valen Chia, Peugeot Owner
Dear Martin
Thank you and your team for bringing in such a wonderful product. I have tried 2 different brands of paint protection system before And while the results were good, the effect doesn't last long enough as promised unless we go back for maintenance. Besides the cost, there is the time wasted sending the car over and having to go back again a few hours later.
With your product, not only do I save money and time, but I must say the result has been more than good and rainy day is a welcome now.
Maintenance is almost too easy and I can now do it at any car park as no rinsing is required. I carry a bottle of water pre-mixed with brilliantshine in my car and this is very useful for getting rid of the occasional bird poo and tree sap.
Thank you once again for making this a joy for all car owners and there is no reason now for a car to not shine with pride - Valen Chia
Dear Martin
Photos and review contribution from Alan, Picanto
After reading the testimonial of the Permanon users, i was so eager to try it out soon. In the end I choose to buy it online, after an agonizing 2 days of waiting finally it arrived.
I drove my car to the nearest petrol station for a quick wash before apply permanon car supershine. It took me 35min to apply to my whole car, coz kiasu mah.
So coincidence the minute i drove out of the MSCP, rain was pouring heavily. I could clearly see the water beading effect on my car. It is definitely a remarkable product - Alan, Picanto Owner
Review of Permanon one month later by Mason
After using Permanon for more than a month, I'm more than surprised that my car still maintains its shine and gloss everytime I wash my car. The smoothness is so nice to touch, just like how you feel when you first clay your car.
Trying recalling the times when you polish and wax your car for the first few days. Immediately after you park and exit your car, you turn around, you admire its shine for a while, and you say to yourself "yes its worth the money and time polishing my car".
With Permanon, I've never failed to turn back and look at my car for more than a month already. The bling factor to my car is so great that whenever I park my car, I will simply turn around and comment to myself "why's my car so beautiful compared to other Avante?"
I even asked my wife about it the other day the same exact question. She just commented "very bright lor, very nice lor. So?"
Pardon her but she can be a total noob to know how hard it is to make your car gloss like that. Even after a month of Permanon, the shine is just... brilliant.
Oh yes, I put a 100% concentration solution on my car. Hehe, I was just feeling extravagent when I did that. Who can expect that, with a 100% concentration, I have never felt that "sun scorching into your skin" kind of feeling anymore! This is a 100% UV protection, and I personally think, its worth every single cent I paid for!
With less than $80 (usual polishing rate), if I can get such effects for a month, I think, there's nothing more that I can complain with Permanon. If you are thinking of getting one, and you are seriously thinking of getting... but you are actually pulling back because of budget, you are not doing a favor for yourself. Try 2 bottles of this Permanon, you will know exactly what I mean when I write this testimonial one month later into the first bottle of my Permanon. I'm not a product ambassador for Permanon, but I'm a sincere buyer that feels that this product must be complimented for their durability and wow factor.
Not to say, Martin was very patient with me as well. I can still remember his aftersales service. You can never find such services in SG anymore. Want to know more? Give him a call, you will know what I mean. - Mason
A review by our very own Watme bro on MCF and Elantra forum
Here's the mini review for the iShine Max package.
It include a Supershine (sealant) and BrilliantShine (shampoo) and other things like complementary spray bottle and applicator aid.
Why there is an extra supershine? because Abachee also bought the $57.90 package and using my name for referral. Therefore i got it for free!
Was being skeptical this product, worrying how good is this product despite the reviews were very good.And then i decide to purchase the iShine Max package from Beacon Enterprise directly.
The sales staff (Jerry) is a very nice guy, he taught me how to wash and apply for the both bottle. Even teaching me another faster way to wash my car and indeed, its really fast.
Today, i purposely went to wash my car despite that my car was washed last Monday only.
I mix the BrilliantShine into my own big waterspray with water, shake it and spray the whole car all over, then waiting for 2min for it to dissolve and remove the dirt. Actually in my mind, i thought, by spraying the car, will it be clean?
It prove me wrong! after i rinse with water for the first time, i can see the car is much more even clean even that i washed on Monday! Then i go for a 2nd rinse and wiping it dry with my microfiber towel.
After drying, i applied the Supershine by mixing 4 cups (20ml) with full level water inside. Then i go by a swiping spray pattern, after for awhile then i start wiping it.
Guess what? im really so surprise that the surface is so silky and smooth! I felt like keep wiping it as it feel so nice. Very Happy. Wiping the whole car finished, i can notice that the car is much more shiny and look just like new car when i just collected my car!
I'm going to use this product till my car no more able to drive! lol! Can you see the water bead actually not sticking to the paint? The beads are actually more bigger in size too! meaning this product work perfectly.
I shall continue monitor if i go into rainy day... Thumbs up! - Watme
Review of Permanon one month later by Burhan
It's been a month since I've used permanon car supershine on my ride and i must say that the coating is still there and to my surprise It's simply won't wash off after many days of rain. Dirt was easily washed away just by spraying or pouring water on it. On my last testimonial i may sound too exaggerating but with the attached photos for proof the shine is still there and you guys can even see reflection of myself, a building and the environment around my ride! I'm really happy with these products and i felt that It's worth the investment with our hard earn dough, don't you think so? - Burhan
Review from Leslie Lim, BMW
Eversince I got introduced to Permanon, addiction ensued and there was no turning back, not only was the products excellent, the service and education of getting your Rides in perfect condition was impeccable. Two thumbs up.
Leslie Lim
Leslie Lim
Review by Zayne - Nissan
I have tested quite a few prestigious brand of sealant and waxes, they give very good showroom wet look shine and smooth but cannot last long even with machine buff.It has been one month after applying the permanon on the car and it is still smooth and shining. Although it does not give the wet look. the shine is still very promising.It is also extremely effortless to apply. Nice talking to martin who brief me on how to apply the product.
I am looking forward to use it again. - Zayne from Nissan
Water beading on a Permanon-ed car, photos contributed by Zentra Bro, Peugeot Club
Want someone to prep your car and apply Permanon for you?
Simply have no time to groom your car?
Your favourite Permanon can now be applied by our Professional Groomers! Our mobile service also means you do not have to travel at all!
All grooming customers can also enjoy the DIY kit at discounted rates!
Call us, Jerry (97661548) or Jonathan (96670623) for more details!
Detailed Review by BC - Peugeot 3008 Owner
After applying Permanon for over 1 week, I think it is time to share my opinion of Permanon.
I’m into my 7th car and I’ve never carry out any polishing on all my previous ride. Though I bought wax and tried to do it once, I found it was too much work. Sending the car for routine professional waxing will burn a big hole in my pocket.
I decided to call Martin after reading about Permanon from car forum as it seems easy enough for me to do it myself and not having to spend too much. Martin’s professionalism convinced me to give it a try.
I mixed the Brilliant Shine shampoo with water and use an empty “Kiwi Kleen” bottle to spray all over the car. The 500 ml bottle was enough to spray over the whole car with no wastage as compared to using bucket. I rinse the car with dripping wet cloth and I could immediately see the water repelling effect by only using the shampoo. I understand now why Martin is strongly recommending the shampoo. Next come the application of the precious Permanon. The applicator (round plastic) wrap with micro fibre cloth is very useful to make sure the nano product is evenly spread and most important, it helps to remove some stubborn stains that was not remove during earlier washing.I took longer to apply the Permanon than stated but within my tolerance level. I was actually enjoying it especially the satisfaction of seeing the fruit of my labour.
The result was just as what was stated. I got a shinning car like when I first collected my new car.It did not rain for the next 2 days but on the 3rd day, I experienced light drizzle which is usually worse than heavy rain as the dirt will stains the glass and body. To my surprise, the car was clean like after being wash, the water flying off the front wind screen is a joy.
I would recommend Permanon to anyone who find it too hard/tiring to do waxing.
Photo Contributions from SkinzWraps
All vehicle surfaces protected by Permanon Car Supershine.
Demo for Honda Civic FD Club on 24th June 2011 @ Kallang Leisure Park
Hi Everyone,
Secondly, My sports rim are always shiny and oil free when using the both products. Also my fear of parking outdoors is bird shit stains which is an irritant to car users like us. After using brilliantshine, the stain comes off easily especially when the stain has been there for along time.
Cheers.
Best Regards
Andrew
Hi Everyone,
Cheers.
Best Regards
Andrew
Photos and review contribution from our valued customer, Clifton Yip, VAGS
Met up with Jonathan last Sun afternoon for self collection and went back home to wash the car. After washing the car with Brilliant Shine, I used the Permanon Car Supershine on the windscreen and windows only as I will be going for my regular groomer this Friday.
As I could not resist and decided to do up the entire car. Pictures speak a thousand words, I have decided to cancel my Friday appointment with my groomer already.
To receive the latest updates,reviews and promotions, click to join Beacon Enterprise Facebook page. =)https://www.facebook.com/Beacon.Enterprise!
Photos and review contribution from our valued customer, William, KIA
Hi, here is my review + pics:
Finally after purchasing for some time, I was free to apply the Permanon Car Supershine. Was a bit skeptical as I have previously tried many grooming services, but the results were always less than satisfactory: Either the results didn't last, wasn't good enough or simply too pricey. So for something that takes only 15-30 mins, I did not have high hopes.
Well, I have to say after trying this is truly revolutionary! Simply spray on and wipe takes away much of the effort that used to be associated with waxing, and results are quite stunning. The surface has now taken on a mirror-like gloss, as the attached pictures clearly shows. Now will monitor how lasting this is , but currently this is the best product I have ever used, bar none!
Regards,
William
Regards,
William
Photos and review contribution from our valued customer, dashMK5,VAGS
Used to be using other grooming products. uses wax,polish,sealant but doesn't last more than a week especially after few pours of rain.
Was reading the vagsg forum one night and stumbled upon this thread. went to Stamford tyre and grabbed hold of the Brilliant shine and permanon package and result was immediate.
even SO said car looks like more shiny and more mirrored look.
Now is the second week and I already did 2 coatings. Result is unbelievable and it takes only 40mins to apply the two products.
Thumbs upp!
Thumbs upp!
Review from across the causeway by Mark!
Just spent 15 mins to apply Supershine on my Vios. The initial result comes out ...really fantastic, though I have not polished my vios before. I will try to apply it again tomorrow. - Mark
Photos and review contribution from our valued customer,Collin Goh
I have started using permanon on my new ride shortly after I collected it mid august. I have applied 2 layers on it, in between 3 washes so far. The effect I say is really not bad, I have frens asking me about it too. Really easy to use, not confusing as other products with many steps, saves time especially. Great product!
Similar topics
» Car grooming to recommend
» Shine Happens - Mobile polish for your Elantra
» Dekitting my black mobile - Selling at low price!
Page 1 of 12
