In total there are 6 users online :: 0 Registered, 0 Hidden and 6 Guests None
Goodspeed-jp Pivot VS/Customised Grounding/Heat Shield/CAI
3 posters
Dear Elantra members,
Volt Stabilizer "RAIZAIN" from Pivot, this brand is a famous volt stab in Japan.
Click on the Below link to see the Details and Benfits from "Raizain"
http://pivotjp.com/product/frame-vs-1-e.html
S
Confirm from Japan, if not full refund.
NOTICE OF FAKE RAIZIN
http://pivotjp.com/imitation/imitation-raizin-e.html
Grounding Services
In addition, I will be providing 6pt grounding services with SILVER coated 10AWG Grounding wire @$60.
Esp for New cars Version which have E Throttle device in their car, our 6 pts grounding will also include the throttle body to help in the responses.
Grounding and the Piovt Vs, improve the performance by producing more stable ignition. This is brought abt by the double effect of strengthened earthing system. This will increase the torque @ Low and Middle speed, Increasing engine reponse.
Anyway grounding and Piovt VS is not new product, have being in the market for a few years. read up more online or u can give me a call at 91462635 so that i can give u more infos.
Grounding wires? How does benefits it you?
•Check your car’s existing grounding pts material, you will be surprised to see that it is the same as the material we are using. We follow strictly the sample layout from car makers so that it will not introduce any complications or side effects. We only want to maximum the existing electrical system of the car.
Pics of wires
Promotions
Package A coated Earth Cables 6Pt Grounding only
$60
Package B
Pivot Raizin Volt stabilizer only
$85
Package C
Pivot Raizin Volt Stabilizer with earth cables with 6 grounding pts
$140
Addition Information
As most of us know, most car makers in order to save cost will reduced the amount of grounding pts in the car as wires are expensive. Therefore most shops or grounding services does grounding with copper wires. Many people think of copper wires as something that has great electrical conductivity. But you will be wrong. Silver and copper are very different in terms of electrical conductivity and also copper wires are heavier in weight. The different between us and the others we used “Silver” earth cable
Check the following website for details in conductivity.
http://www.lehigh.edu/~amb4/wbi/kwardlow/conductivity.htm
Don’t just listen to me. Just check your car existing ground pts and you will see that they also used silver earth cables for grounding purpose. I believe that the car makers know their work with the tons of research and investment in the car making biz. I am just following the sample layout by the car makers instead of adding in addition foreign/different wires which may introduce more complications or side effects.
Nick/Contact no.
1)
2)
3)
4)
5)
6)
7)
8
9)
10)
You can contact me, Alvin@91462635 to discuss about the installation or queries. If you live near Amk or Sengkang i can even show you example of the grounding pts.
Sample pics of the installation
Below is a sample of the testing we show to the owner after we finish the grounding. we will do a amp/current test to show that the wires are all connected/Live and running. In addition, we will grease all ur connection pts esp the +/- pts of the Battery with hi-temp grease so that it will not rust.(Rusting will cause the connection pts to decrease in current, as there are impurities)
More pics on recent installations
Jazz
Points to be taken, recently was help a bro installing his used pivot I noted that there are more and more Imations in the market now. Below is the attached drawing.
Just some pointers to share, capacitors for the RAIZIN show be “K” shape, not “T” or “-X”
In addition, the pivot products I selling have Serial No. so that if you are installing with me, I will copy down your license plate and pivot Serial no. for reference.
Take note that this is the proper way manufacturer recalling back products. Do not buy products that don’t offer serial no. as they will be most likely be Imations as there will be no way the manufacturer can recall which products are defects.
Integra
FD Civic Type R
Mitsubishi Colt R 0
Lancer EX
Fiat Pundo
S
Grounding Services
Pics of wires
Promotions
$60
Package B
$85
Package C
$140
Nick/Contact no.
1)
2)
3)
4)
5)
6)
7)
8
9)
10)
Jazz
Integra
FD Civic Type R
Mitsubishi Colt R 0
Lancer EX
Fiat Pundo
Goodspeed- Learner
Goodspeed- Learner
Re: Goodspeed-jp Pivot VS/Customised Grounding/Heat Shield/CAI
Upz for the good service from Goodspeed.
sky devils- Moderators
Hi....140 include installation? If yes...location of installation at sengkang? Pls advice
cichlidevils- Moderators
cichlidevils wrote:Hi....140 include installation? If yes...location of installation at sengkang? Pls advice
Installation can be done at Serangoon bro. Lol...
Goodspeed- Learner
Yes Bro. Can me.at 91462635
Goodspeed- Learner
