In total there are 6 users online :: 0 Registered, 0 Hidden and 6 Guests :: 1 BotNone
Finevu CR300-HD
4 posters
Finevu CR300-HD
Hi, I had ordered this product yet to collect it. Just wondering those who had installed this product. What's the standard default installation way? I mean the wiring part, tap to car battery or start/stop ignition or some other methods?
Just want to gather more ideas before I collect my camera
Thanks!
Kiligulu- Moderators
Re: Finevu CR300-HD
If you want it to operate in parking mode when you off the car, you need to connect it to the battery, other the 12v power point is ok.
I got connected directly to the battery so it runs 24hrs.
bomia- Learner
Re: Finevu CR300-HD
bomia wrote:If you want it to operate in parking mode when you off the car, you need to connect it to the battery, other the 12v power point is ok.
So no worries to drain the car battery right? Does that mean we will change our car battery faster?
We need to tell the workshop how we want it to be connected or they automatically know what to do?
Re: Finevu CR300-HD
i got mine 2 weeks back from online as well. the supplier got a designated workshop you can bring it to. they will settle everything.Kiligulu wrote:bomia wrote:If you want it to operate in parking mode when you off the car, you need to connect it to the battery, other the 12v power point is ok.
bayside- P Plate
Re: Finevu CR300-HD
Good thing about CR300 is it cut off the power if it detect low voltage ( 11.5v if I remember correctly) from the supply, saving the battery from flats.
Like Bro bayside, I also got mine online and installed at the designated installer, you just need to decide if you want it run 24 hours or only when you drive.
Cheers!
bomia- Learner
Re: Finevu CR300-HD
Thanks!
How much you pay for it ?
ahnah- Driver
Re: Finevu CR300-HD
Thanks for the info, will collect my camera soon once got the new ride
Re: Finevu CR300-HD
Thanks!
Got it @ $398 from this guy called Xaiver
Re: Finevu CR300-HD
Thanks!
Not bad leh ... some offer at $400 +++
ahnah- Driver
Re: Finevu CR300-HD
haha ya ahnah,
I believed some brothers here also got it from him
Re: Finevu CR300-HD
got mine from Xavier as well, 398 + 30(installation)+8(for a converter) @ car beauty. that is the total cost.Kiligulu wrote:ahnah wrote:Kiligulu wrote:
Thanks!
bayside- P Plate
Re: Finevu CR300-HD
bayside wrote:got mine from Xavier as well, 398 + 30(installation)+8(for a converter) @ car beauty. that is the total cost.Kiligulu wrote:ahnah wrote:Kiligulu wrote:
Thanks!
Hi bayside what's the converter for????? Can explain?
Re: Finevu CR300-HD
Thanks!
I added a switch to the +ve of the supply, because you need to power off the unit before you remove the SD card.
bomia- Learner
Re: Finevu CR300-HD
Wah all so chim one, I electronic gadget idiot leh....
Re: Finevu CR300-HD
I didn't know there is a need to power off the unit to remove the SD card. i just plug the SD card out from the cam. will it have and side effect?bomia wrote:I added a switch to the +ve of the supply, because you need to power off the unit before you remove the SD card.
bayside- P Plate
Re: Finevu CR300-HD
bayside wrote:I didn't know there is a need to power off the unit to remove the SD card. i just plug the SD card out from the cam. will it have and side effect?bomia wrote:I added a switch to the +ve of the supply, because you need to power off the unit before you remove the SD card.
That's what Xavier told me, I guess like pluging out USB from PC also need to disable the connection first loh.
bomia- Learner
Re: Finevu CR300-HD
Finally installed my FineVu CR300 @ ZMC. Itchy hand go remove the camera when reach home, had a hard time fitting it back. Ended up adjusted the angle. Now dunno whether angle correct bo as dun have the display device to view live......
