In total there is 1 user online :: 0 Registered, 0 Hidden and 1 Guest None
GB : Max Up Ignition Coil Booster ( The Immediate Power Solution )
Unleash the ' hidden ' power from your ignition coil with this device and feel the immediate power during acceleration.
It's a Plug and Play device and doesn't require cutting of wires and cables ( No void of car manufacturer warranty )
It maintains the ignition voltage between 12 VDC to 16 VDC. Higher ignition power and stronger spark thus will improve burning efficiently. The optimized and stronger spark provides a much complete combustion which results in better throttle response, better fuel efficiency and torque power.
This unit is specially designed and comes with a safety fuse and a bypass safety on/off switch ( In case of any failure to the unit, the unit can be reset to original stock setting and the car can be operated normally )
* Comes with 1 year ( one to one replacement ) warranty *
Retail Price : $130 ( With installation )
GB Price : $100 net ( With installation )
POC : Daniel Poh
Mobile : 96944096
Re: GB : Max Up Ignition Coil Booster ( The Immediate Power Solution )
* Please note that this gadget is not a VSD system which will steps up your DC voltage to 18VDC which in the long run will damage your ignition coil *
Free trial available if you are not convinced in this product !!!
Please refer to the below stated link for more information and feedback -
https://www.facebook.com/media/set/?set=a.497976050285769.1073741877.148196965263681&type=1&l=a1d1f1f015
